During the winter months, the cold air can dampen enthusiasm for riding. If you plan to put your electric bike away for an extended period during the colder months, it’s essential to follow proper storage tips. Extreme winter temperatures can significantly affect the electrical components, and improper storage may lead to functionality issues. This article will introduce effective winter ebike storage tips, as well as advice for winter riding.
Winter impact on ebikes
During winter, the frequent rainy and snowy weather increases humidity levels, which poses a  threat to the ebike components.
One of the most common effects of winter riding is a reduction in battery life. Cold temperatures require the battery to expend more energy to maintain normal operation, leading to faster consumption during rides. To help mitigate this issue, consider maintaining a lower speed while riding in winter; this allows the battery to heat up gradually and supports its overall health.
It's also important to monitor tire pressure when riding in cold weather. Low temperatures will affect the tire pressure, so be sure to check and replenish it to the recommended level. Proper tire pressure enhances your riding experience and improves safety.
The worse winter weather and the lower temperature make riding more challenging. Choose tires with stronger grip to maintain the stability and help you through slippery road more easily.
snow on ebike
Prepare for winter storage
1. Clean
Before storing the electric bicycle, ensure that it is thoroughly cleaned to avoid impurities that could lead to oxidation or damage to its components. Cyrusher electric bikes keep water resistance levels, allowing you to clean them with a soft cloth or gently rinse them with a garden hose. However, avoid using high-pressure water guns, which can easily cause damage to the components. Carefully clean the areas prone to dust accumulation, such as the tires, chain and gears. Use a soft cloth to clean sensitive parts like the battery surface and display screen to prevent water damage. After cleaning, put it in a well-ventilated area to dry the bicycle completely. Any residual moisture will cause components to rust or damage during storage.
2. Inspect
(1) Check the frame and front fork for any bending or deformation that would significantly affect the stability, and for any rust caused by exposure to air.
(2) Ensure that the tire pressure is kept within a reasonable level to avoid flat spots during long-term storage. Pay attention to whether the tire tread has cracks and repair them in time if any.
(3) Test whether the brakes are running smoothly and replace worn brake pads in time to ensure braking sensitivity.
(4) Check the chain if work properly. Before long-term storage, lubricate it after careful cleaning to ensure smooth operation after storage.
After thoroughly cleaning and inspecting your bike, choose a suitable storage location to ensure you can resume riding quickly in the future.
Where to store
Indoor vs outdoor
When considering storage options, one might wonder whether it's better to store bikes outdoors or indoors. Storing in an outdoor shed can save space at home; however, it also comes with hidden safety hazards. If conditions allow, it is recommended to store in a dry and cool indoor space, such as a garage. Regardless of where you choose to store your bike, try to choose a location that protects them from extreme weather conditions, direct sunlight, rain, snow, and moisture. Also, keep security measures in mind to prevent theft and property loss.
Apartment
For riders living in apartments, it is wise to choose a folding e-bike when buying because it saves half the storage space by folding the frame. Normal electric bikes can also be disassembled and stored separately to save space. The location can be in a corner of the living room or hung on the wall (not applicable to everyone). If your apartment provides a protective parking shed and with a high security level, you can also lock the bike in the outdoor shed. Make sure to choose quality locks and remove expensive battery components, etc. However, it is inevitable that storing the bike outdoors always carries the risk of theft, knocking it over or vandalism.
Storage tips:
  1. Use bike cover
In winter, the lower temperature and the high humidity make it dangerous to leave an ebike exposed outdoors for a long time. You can buy a waterproof protective cover to wrap the electric bicycle to provide an extra layer of protection.
  1. Store battery & LCD screen separate
Disassemble the battery, display and other electrical or water-intrusive accessories and store them separately. For some components that cannot be disassembled, choose to cover them with some waterproof materials. Due to the high cost of battery components, you need to pay extra attention to the storage environment, stay away from fire sources, and maintain a suitable temperature and without humidity.
Tips/accessory for winter riding:
Although winter winds can be quite challenging, winter riding has its own charm. For riders who prefer not to leave their e-bike locked away in the garage, proper preparation is essential to fully enjoy winter riding.
  1. Helmet: Always wear a helmet to ensure safety while riding.
  2. Protective Gloves: Long exposure to cold winds can cause joint stiffness and affect bike operation. Opt for windproof gloves to help prevent these issues.
  3. Mudguard: Mudguards can effectively avoid snow and fallen leaves on both sides of the road from splashing into the internal components of the tire.
  4. Layered Clothing: Dress in multiple layers for cycling, with the inner layer made of quick-drying materials. Choose bright-colored outer layers to enhance visibility in snowy conditions.
  5. Headlights for Visibility: With shorter daylight hours in winter, ensure your bike is equipped with a reliable light source, such as front headlights, to maintain visibility on the road.
  6. Proper Battery Care: After riding, allow your e-bike and battery to return to room temperature before storing or recharging them. Avoid placing them in overly warm environments immediately after use, as extreme temperature changes can damage the battery and other components.
ebike with bright headlight
By following these tips, you can enjoy the thrill of winter riding while staying safe and comfortable.
Regular check
During storage, electric bikes should be checked regularly for any signs of rust or hidden damage. Monitor tire pressure frequently to prevent wheel deformation caused by low PSI. Most importantly, ensure battery health by keeping the charge between 40% and 80%. Avoid excessive battery depletion, as this can harm the battery's capacity.
Careful inspection before riding
After long-term storage, electric bikes should be carefully inspected before hitting the road again. If you're not familiar with the necessary checks, consider visiting a local bicycle shop for assistance. The inspection should ensure that:
  • The battery supply is stable
  • The gears are functioning properly
  • The braking system is effective
  • The chain is adequately lubricated
  • The gear lever operates smoothly
  • The display screen is clear and readable
Follow reasonable steps to store your e-bike if you don't intend to ride it for a long time. Regular maintenance can prolong the ebike lifespan and ensure a safe riding experience. If you want to experience the fun of riding in winter, take protective measures and fully embrace the fun of winter riding.
ride ebike in snowy weayher
FAQ
  1. How often to check the stored ebike?
Check your e-bike every few weeks or at least once a month. During these checks, look for signs of rust, monitor the tire pressure, and, most importantly, assess the battery health. Make sure to charge the battery regularly to prevent it from running out of power.
  1. What is the best battery charge for storage?
When the battery is stored for a long time, it is best to control the battery charge to 40%-80% to keep the battery healthy.
  1. What is the most suitable temperature for storing ebikes?
The ideal temperature for storing electric bicycles is typically between 10 degrees Celsius and 20 degrees Celsius (50°F to 68°F), which corresponds to normal room temperature.
