Cyrusher, the professional e-bike producer, will launch pre-sales of the Nitro, the company's first mid-motor model, in late July. This is an ebike with great comfort and speed for your 2023 riding adventure. Riders will enjoy a pleasant and effortless ride on the Nitro, as well as greater power, speed and control compared to a hub motor electric bike.
The Nitro, appearing as the first mid-motor model, integrates design aesthetics, technological innovation and a variety of other factors to ensure riders have a pleasant and smooth riding experience that exceeds expectations.
Specification
Model |
Recommended |
mid-drive ebike(step-through) |
Motor |
1000W Bafang (1500W Peak)and 160Nm |
Range |
up to 85miles |
Battery |
48V 20Ah Samsung Li-battery |
Transmission |
Shimano 10-speed transmission |
Tires |
Kenda 26"×4.0" puncture-resistant fat tires |
Brakes |
Star Union fully hydraulic 180 front and rear disc brakes |
Load capacity |
200kg |
Riders Height |
5'7" ~ 6'6" (170cm ~ 200cm) |
Bike Weight |
66 lbs (30 kg) / 74 lbs (34 kg) with battery |
Color |
black, red and blue |
Light |
250 lumen LED |
Display |
Bafang full color backlit display |
Horn |
included |
Suspension |
front and rear air suspension |
Warranty |
2-year |
An attractive aesthetic design style - three color options
The Nitro follows the color-rich design style of the Cyrusher models while incorporating its own design aesthetics, making it a colorful option for many riders. The Nitro has a color-blocking design that keeps the black color of the rear frame while varying the fork gradient colorways to create a unique frame style. The Nitro is available in three color options, black red, and blue, to suit different rider preferences.
The ultimate speed experience - the mid-motor configuration
There is no doubt that this mid-motor Nitro was developed to meet the needs of the rider. The highly effective mid-mounted motor, which has been improved to provide an unprecedented level of power, is the most significant addition to the updated Nitro. The utterly improved 1000W Bafang mid-drive motor makes the e-bike's ride feel more dynamic responding readily to the rider even at maximum speed. To optimise the bike's balance, the mid-mounted motor is incorporated directly into the pedals and cranks. This also results in more efficient power transmission from the motor and higher climbing ability and weight lifting capability.
In addition, unlike other hub motor categories, the Nitro delivers 160 Nm of torque power, offering more flexibility for speed variation and a genuinely powerful speed sensation.
Powerful energy supply - 48V 20Ah Samsung Li-battery
The battery that powers the mid-mounted engine on the Nitro is still as secure, water-resistant and durable as the usual model. In combination with the mid-motor's more efficient power transmission, the 48V 20Ah battery allows the bike to cover up to 85 miles with its reliable capacity. Along with extending the vehicle's lifespan and durability, it can efficiently charge up to 800 cycles, making it an extremely cost-effective option.
Safe braking capability - hydraulic brakes
To improve braking power, Nitro chose twin-piston calipers. The twin-piston calipers allow for a larger surface area of contact with the brake rotors which increases the friction when the brakes are applied. Hydraulic brakes enable quicker braking reactions and improved traffic safety. The extra engine cut-off feature ensures that the brakes can be applied quickly and effectively in the event of an emergency, providing an extra layer of safety and security. The Nitro helps the rider cycle freely on the road and stop easier, achieving a better balance between thrill and safety.
Solid road pioneering - puncture-resistant fat tires
Nitro, with a 26*4 fat tire, is developed to be a powerful means of transportation. Fat tires offer much better traction and cushioning than regular tires, allowing you to easily navigate through difficult terrains like sand and mud. Therefore, Nitro is a great tool for exploring the city and the outdoors, with the ability to twist and turn through crowded streets, climb steep slopes and ride along soft beaches. Besides providing stability on slippery surfaces, Nitro can handle higher speeds with less chance of blowouts.
The top comfort escort - front and rear air shock absorption
The powerful Nitro is a full suspension electric bike with front and rear air suspension, guaranteeing maximum comfort. It offers better cushioning than previous generations. The adjustable front and rear air suspension features the highest configuration, allowing it to take on more challenging terrain without sacrificing comfort. It offers 135mm of thread that can be adjusted separately for terrain variations, boosting the damping effect for an enjoyable riding experience.
Reliable load capacity - upgraded to 200kg load capacity
The Nitro was designed with a mid-motor that reduces the bike's center of gravity, giving it outstanding balance. This allows the bike to carry up to 200kg of cargo. Additionally, its high load capacity ensures that the bike's weight doesn't negatively impact its performance.
Smooth gear transport - Shimano 10-speed transmission
The drive system's reliability is essential in order to ensure that the Nitro will be able to take full advantage of its improved high torque capabilities. The Shimano transmission helps to reduce wear and tear on the chain, making it more durable and efficient. The 10-speed pedal assist mode option gives riders the flexibility to choose the speed setting that perfectly suits their needs, ensuring that the bike can be tailored to meet the requirements of any type of rider.
All the details are there - the accessories
The Nitro comes with its own Led front and rear tail lights which provide excellent illumination and make sure that the rider is able to ride in dimly lit conditions. And, the Nitro has an updated Bafang back-lit display that allows the rider to more clearly track data such as speed, battery life, range and pedal assist levels.
Reliable after-sales service
The Cyrusher team consistently prioritizes the customer's needs and provides them with outstanding service. The team is available for customer inquiries and feedback 24/7 and offers fast and efficient response times. A long-term guarantee with a two-year product warranty backs the Nitro. The reliable customer service demonstrates Cyrusher's commitment to customer satisfaction, giving Cyrusher a distinct competitive edge.
Price tag
Priced at $4499, the powerful Nitro opens up even more riding possibilities for riders. The Nitro is equipped with a powerful engine and advanced features such as an adjustable suspension and quick brakes. This makes it a great choice for riders looking for a performance-oriented ride. If you are interested in the powerful Nitro, you can find more details on the official website.
What is the significance of the development of a Nitro?
Sustainable energy solution for a greener planet
Cyrusher has always been committed to green and sustainable development, exporting green travel vehicles worldwide and launching high-quality electric mobility tools to support sustainable development. By developing Nitro, Cyrusher demonstrates its commitment to its original goal. Nitro is an innovative and powerful electric bike that offers riders the ultimate convenience, comfort and performance. The company is helping to reduce carbon footprints and support a green earth by encouraging more people to cycle.
Leading the industry to new heights
A healthy competitive relationship provides a favourable opportunity for the industry to upgrade and change. The Cyrusher e-bike has been designed to maintain its own unique characteristics while responding to the changing market trends and offering more competitive value-for-money models to meet the needs of cyclists of all ages and performance levels. The launch of the Nitro is Cyrusher's newest work in the mid-motor field. With high quality range, powerful running ability and ultimate comfort, it is undoubtedly the most competitive product of its kind. Cyrusher will keep improving its technology and services in the future to offer better value to more riders and set a new benchmark for the sector.
A constant insight into customer needs
The Nitro is based on the company's insights into user needs and changing industry standards. Cyrusher insists on being user-centred, with high-quality components that have been repeatedly researched, tested and polished over a long period of time. The Nitro integrates comfort, safety and stability to bring riders the ultimate rewarding experience beyond expectations. The Nitro can be used freely on any road and with the wind blowing gently in your face, you’ll have a more comfortable and enjoyable riding experience. Cyrusher is always moving forward and making great strides.
The Nitro is a performance breakthrough and aesthetic reinvention that offers speed, control and comfort and provides riders with a more portable and efficient travel tool. Powerful performance has made it the best mid-drive ebike choice.
About Cyrusher
Cyrusher is a reputable producer of electric bicycles for professionals that have been successfully marketed in more than 10 nations worldwide. The brand's electric bicycles pass rigorous international quality tests and meet CE, UL, Rhos and FCC requirements. Additionally, Australia, China, the EU, Japan, Korea and the USA have registered and approved the brand. An offline store test-ride service has also been introduced in a number of nations, including the USA, UK and France. Cyrusher will keep expanding its range of vehicles to satisfy the needs of more riders, offering a solution for zero-carbon, fast and convenient urban commuting.
Cyrusher Contact:
Phone: 01134900889
Email: support@cyrusher.com
In the United Kingdom, Cyrusher allows enthusiasts and future bike owners to experience the awesome lifestyle that Cyrusher electric fat bikes can deliver by visiting our store. Before visiting, pay attention to the hours of operation.
Business Time: Thursday and Saturday: 10:00 am - 3:00 pm
Address: Unit 15, Steadings Business Centre, Church Rd, Maisemore, Gloucester GL2 8EY, United Kingdom
The Best Electric Bikes for Summer Riding
How to Make Your Ebike Go Faster
